I have an I & T manual and it's a starting point but I'd like to hear from somebody that's actually opened up a few. Without putting on an indicator I'd guess maybe .050" play. I understand the shim removal to take up play but find it a bit odd that a tapered bearing doesn't butt up to a solid shoulder on the axle.
What are the more common issues? Wear where the axles touch? Common for bearing to shift inward? Just plain bad bearings?
What is a typical thickness for the shim package?
The hour meter shows 1100 hours, but I don't know if its working. From the overall looks of things it might be close.
