| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Massey w/ Perkins 1004.40T vibration?
[Return to Forum]
| Author |
[Modern View]
| jkloepping
10-30-2012 15:55:00
108.196.216.131
I have a Massey with a Perkins 1004.40T that has a strange engine noise/vibration. This tractor is new to me, so perhaps the sound is normal. It sounds like a low frequency "whomp whomp whomp" in time with the engine speed, even when stopped with both main and pto clutches disengaged. The tractor only has 1600 hours, and I just adjusted the valves and did a complete service. I plan to loosen the belts and run without the accessories.Sounds like an out of balance noise to me, a bit like what sometimes happens when you drive a car down the freeway with the window open juuuust right. The tractor runs and pulls fine, never heats up and is great otherwise, but this noise is really annoying, now that my attention has been drawn to it. |
[Reply] [No Email] | |
| samn40
11-01-2012 02:22:13
217.43.214.254
Re: Massey w/ Perkins 1004.40T vibration? in reply to jkloepping, 10-30-2012 15:55:00
| Balancer gears???? Sam |
| MJ in the UK
10-31-2012 05:31:22
81.131.196.235
| Had a bit to do with these engines, i am gussing worn timing gears. MJ |
| jkloepping
10-31-2012 07:12:29
70.36.167.208
Re: Massey w/ Perkins 1004.40T vibration? in reply to MJ in the UK, 10-31-2012 05:31:22
| The engine looks so new, with only 1600 hours. When I had the valve cover off everything looked great. The engine doesn"t smoke out the exhaust or breather, so I wouldn"t suspect engine wear like worn timing gears. Is this a particular problem on that model Perkins? |
| MJ in the UK
10-31-2012 08:43:41
81.131.196.235
Re: Massey w/ Perkins 1004.40T vibration? in reply to jkloepping, 10-31-2012 07:12:29
| I work on these engines fitted to MANITOU telescopic handlers. Had amachine il last month with bad vibrations and the timing gears were worn out, the teeth on the gears were at a sharp point. Also the idler gear bush was worn badley. MJ |
| jkloepping
10-31-2012 15:21:36
108.196.216.131
Re: Massey w/ Perkins 1004.40T vibration? in reply to MJ in the UK, 10-31-2012 08:43:41
| On my engine, the oil filler cap is just above the timing gear for the injection pump. The teeth of that gear look fine. Did you find that all gears were worn on the engine you looked at? |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
