Wheel weights
I'm with you, water has better places to hide than inside tires. And calcium cloride has no place outside the ocean.
I had an x USAF tractor, and now a MF3165 that had concrete weights. Basicly a set of bolts thru the wheel center holes iron weights would bolt to, but into a pan, with rebar welded to it, and a mortar mix... laying down of course.
The one on the 3165 was once a propane tank. I'll take a pic in the morning if you'd like, the other tractor is long gone.
