Anonymous-0
I just bought a 285 the current hydraulic controls on the right side of the seat run the valve on the left side of the seat. From that valve runs lines to the back that are quick connect swivels. From there are long hoses that run to the front axle around and back to the loader hook up. I would like to use the rear quick connects for a fork lift mast and tilt cylinder and re-do the loader. Like to add a load joystick but at a loss on how to tap into the juice. The two lines out are steel tubes. Like input on size and type and where to get a loader control and how to feed it! Thanks
