Does any one have pictures of how the hyd, system on a 90 with 3 point should look. now my 3 point works and cyl. valve does not. I have after market valve on it from my dead uncle that tryed making it have two remotes and the 3 point work. I tried taking all that crap off and having one remote and 3 point. Any Help? Thanks
Justin
If I remember right you will have either or. As you are sitting on the seat look down between your legs and you will see a little wheel about 1 1/4" in diameter. It has to be screwed all the way in for one to work and all the way out for the other to work. Both will not work at the same time. PIA. for this reason I won't buy a super 90 even though I like them.
Merle
