dwag
Rebuilding steering gear box and looking for parts. Found most at Steiner but wonder if there are other aftermarket sources out there? Could use steering gears/shafts also. tanks, john
I have bought many parts, including steering parts from this very site. Click on the "tractor parts" link in the upper left hand corner of the screen.
I have found that no single source seems to have all the parts so you have to look around. Try entering the MF part number for the item you are looking for into Google and you should get a list of sources if they exist. Is there a specific part you are having difficulty locating?
Dan
Steering sectors LH/RH, Mine are very pitted. Found steering shaft and most other parts. thanks, john
This site has the left/right steering sectors. They are the power steering sectors but in the item description it states they can be used for the manual steering box if both left and right sectors are both replaced. Given how much they cost, you may want to call some salvage yards and see if they have some nice used sectors.
Dan
