william37
New User
I PURCHASED A PITTSBURG 250 BUSH HOG IT WORKS JUST FIND, MY PROBLEM IS THAT I DON"T KNOW IF I HAVE IT HOOKED TO THE TRACTOR RIGHT. WHAT HAPPENS IS THAT WHEN I SET THE HYDRAULIC AT THE HEIGHT THAT I WANT IT WILL STAY SET FOR A WHILE BUT THEN IT WILL EITHER GO TO THE GROUND OR GO UP 8 INCHES OR SO.
Thanks
What kind of tractor do you have? That would help a lot. You are probably trying to use it with draft control. And also you don't have a Pittsburg Bush Hog. It's either one or the other. Please use upper and lower case when typing.
