I bought the 175 with a MF loader that I was looking at. Now I'm wondering about some things;
1, What year is it? I can't find the serial number. I looked for evidence of the tag on the panel below the steering column but found none. Are there any other alternate locations for the serial number?
2, The loader is powered by the internal pump and the loader speed is pretty slow. Is there a way to speed it up with a bigger pump without mounting an external pump?
3, The lift arms travel to the up position no matter what position the control levers are in. When the lift lever is in the down position; I can push them down by my body weight.
4, The lift arm motion is jerky and actually has a pulsation to it when raised or pushed down by hand when the valve is in the lowered position.
Thanks
Thanks
