| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: MF35 difficult to shift -- at times
[Return to Forum]
| Author |
[Modern View]
| Dale in WV
10-10-2012 09:04:53
184.19.192.223
"brother-in-law ", when using a scraper blade, "discovered" the family tractor now difficult to shift. 1962 MF 35 diesel deluxe. Made the clutch pedal adjustment today per info from Big Dean CD and instructions from DavidP in the land down under. Shifts fine when starting out - high or low range. Drive a hundred feet and you nearly have to shut it down to find neutral again...which was the status BEFORE making today"s clutch pedal adjustment. Stand on the clutch and it still creeps in gear. Must I check PTO adjustment now, or are the symptoms related to an adjustment there? I think its a danger to drive until this is addressed. |
| Dale in WV
10-10-2012 13:07:28
184.19.192.223
Re: MF35 difficult to shift -- at times in reply to Dale in WV, 10-10-2012 09:04:53
| Thanks for the advice and also geography lesson. I believe I will position MYSELF on the drivers seat and he doing the inspection below. If we find its a corrupted lining, that means splitting it, right? |
| DavidP, South Wales
10-10-2012 13:22:34
2.97.137.1
Re: MF35 difficult to shift -- at times in reply to Dale in WV, 10-10-2012 13:07:28
| Hi, Yes it will. There is not a lot that you can do through the inspection hole. DavidP |
| DavidP, South Wales
10-10-2012 10:14:14
2.97.137.1
| Hi Dale, No, not in OZ, I'm in South Wales, not New South Wales!!!!! If the clutch is not freeing there are a number of possibilities. First of all remove the inspection plate under the clutch housing. Using a flashlight inspect the clutch unit for anything that looks to be amiss, one loose release lever screw, position of a release lever different to the others etc...Have an assistant press the pedal whilst you watch the operation. The pedal movement in each stage should be clearly related to positive movement of the release levers and main pressure plate as it moves rearwards. If it only tries to lift or the movement is absolutely minimal you need to find where the operation movement is being lost. Check that the movement is even all round. If you have positive movement of 1/16 to 1/8" in the first stage that would be about correct. If the plate is still not freeing it could be down to contamination of the lining/s, or rust causing it to drag. With the pedal at the bottom of the first stage there should be no clearance on the PTO adjusters. Push down through the second stage. There should still be clearance between the spring coils. I think that a very likely cause of your problem will be a broken lining on one side of the main plate. Frequently a piece of the lining will lodge somewhere else around the face. This will give two thicknesses of lining on one side. Normal lift of the pressure plate is not enough to free it hence you will get enough drive to move the tractor. Normally this can be seen by one 'corner' of the pressure plate sitting higher than the other two as you turn the flywheel by hand. Check it visually first and I think you will see something of the above. DavidP, South Wales |
| Gearhead210
10-10-2012 09:35:45
72.241.59.210
| Could be a pilot bearing in the flywheel trying to lock up- that will cause all sorts of issues if left alone (if it is the problem). Otherwise, just adjusting the throwout fork should at least get it to stop for you. take all backlash out of the pedal and se how it acts then. It is bad for the throwout bearing to run like that a long time, but it will tell you whether the clutch reacts at all to adjustments. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
