| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Re: MF 250 Oil pressure low and squealing/knocking
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| samn40
10-09-2012 00:12:55
81.135.25.67
Looks like your oil level was too low for too long! I think you need to at least drop the sump and check your shell bearings for scoring.You may have to remove and regrind the crankshaft. Do not be tempted to start the engine until you have found the problem. It is common enough to have the bearing seize and snap the endcap bolts and then stick the conrod out through the side of the block, commonly called 'sticking a leg outta bed!!' Good luck...Sam |
[Reply] [No Email] | |
| DavidP, South Wales
10-10-2012 01:06:34
2.97.137.1
| Hi, To add to Sam's comments the removal of the sump is the first step. On the 250 you will need to remove the front axle casting first to clear the stud. Check the suction pipe from the strainer to the pump. Later tractors had a rubber grommet to hold the pipe but there should be no problem there. Slide each con-rod on the crank in its play. I suspect that number 3 will be faulty as it is the furthest from the oil pump and normally suffers first. DavidP, South Wales |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
