MF 65 hydraulic question
Tequila
This tractor has a remote sending valve mounted on the right front corner of the lift cover. Piped to a control valve and quick disconnect bolted to the right fender. Ugly set-up. If I remove that valve on the lift cover, what do I need to plug those holes??
Thanks for the info, finally got AGCO site to come up on parts. Seen the cover, hope I can afford one.
I just selected internal on the valve and plugged the holes with 3/8 pipe plugs. Your results may vary.
Aaron
(quoted from post at 16:33:52 10/03/12) This tractor has a remote sending valve mounted on the right front corner of the lift cover. Piped to a control valve and quick disconnect bolted to the right fender. Ugly set-up. If I remove that valve on the lift cover, what do I need to plug those holes??
Is this the valve and hoses for rear remotes? If so, do you want to sell it? Let me know. Thanks Todd.
