| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: wireing starter 165 massey
[Return to Forum]
| Author |
[Modern View]
| siler
09-29-2012 18:24:08
184.155.118.60
Boy do I feel stupid on this one. I had a starter go out on a 165 massey three cyl diesel. When I unbolted this thing I droped it and it had a black wire hooked to the solinoid short wire with the loop on one end and a metal plug on the other. I took it to a shop and he tore the starter apart and lost the wire as it was left on the starter.Looking at whats left. I have the loop end for the battery to the starter, a small red wire which I am sure goes to the solenoid. A black wire with large loop that looks like it goes on with the battery line to the hot on starter. At first I thought it was a ground wire but the loop is big. I dont see a ground anywhere. Wondering if this thing grounds to the frame. Also the black wire that was lost I AM SURE WENT TO THE solenoid also as I remember it. But can you believe it I cant find anywhere that it might plug into if I replace it. I followed the harness back thinking there might be a plug and only the red and black wire inside the wire caseing. Anybody have any ideas before I burn this thing up? craig And |
| Don-Wi
10-18-2012 19:24:19
75.249.124.212
Re: wireing starter 165 massey in reply to siler, 09-29-2012 18:24:08
| Do you have the right shifter in the start position? What if you jump the terminals, the smaller one that the wire connects to, to the larger one the battery cable attatches, with a screw driver.
******** MAKE SURE IT'S OUT OF GEAR BEFORE JUMPING WITH A SCREWDRIVER!!!!!!!!***************
Donovan from Wisconsin |
| siler
10-19-2012 06:46:38
184.155.118.60
Re: wireing starter 165 massey in reply to Don-Wi, 10-18-2012 19:24:19
| | After all the reading on neutral switches I decided to pop the cap and take a look. Low and behold there was one of the wires loose on the switch. PUt it back on and fired right up. thanks donovan and all for the help great forum. craig |
| siler
10-17-2012 13:09:26
184.155.118.60
Re: wireing starter 165 massey in reply to Steve_VT, 09-29-2012 18:24:08
| Quoting Removed, click Modern View to see Well I finnally got around to hooking it back up. Guess what new starter wont crank now im lost. The dang thing was running when the starter busted out so now not sure what to do. Checked battery and we got juice but no crank even with the new starter.
craig |
| MF#1
09-30-2012 07:10:35
209.209.130.204
| "I have the loop end for the battery to the starter, a small red wire which I am sure goes to the solenoid. A black wire with large loop that looks like it goes on with the battery line to the hot on starter. At first I thought it was a ground wire but the loop is big. I dont see a ground anywhere. Wondering if this thing grounds to the frame." No, the starter frame is grounded to the tractor block. What you said above is correct, battery cable PLUS black wire on the HOT, red wire to the small solenoid connection. This works on most US MF diesels whether 3, 4, or even 8 cylinders. The color of the wire is variable. |
| siler
09-30-2012 07:34:18
184.155.118.60
Re: wireing starter 165 massey in reply to MF#1, 09-30-2012 07:10:35
| | Thanks mf-1 thats what I thought but did not want to hook it up without asking thanks again craig |
| siler
09-30-2012 07:32:01
184.155.118.60
| | Ha Ha well shows what I know I always thought it was a 3 cylinder maybe its a four. craig |
| Roy in UK
09-29-2012 23:25:36
86.161.74.150
| 165 Massey three cyl diesel? That can"t be right. The MF 165 had a 4 cylinder engine. The 135 and 148 had the 3 pot. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
