1947 Massey Pony overchatging battery
smbroxbury
New User
Just got a Pony and will run but overcharge the battery , try to disocnect the battery when run ,but I loose power.
Any one can give me some idea how to fix.
Change the regulator?
How hard its to switch to 12 vlts
The charge rate is controlled by the light switch, even if there are no lights. An early 47 should have a cut out to turn on and off the charging. Checking battery voltage when running and not should tell if the system is working. A repair shop should be able to test your generator.
