Thank you i saw large plate in the oil pan that had a drain plug plus a larger bolt in center would this be the oil filter?
Thanks
That's it, pull the drain plug then remove the cover by first marking its location as most old tractors have had some bumps on rocks and such and when replaced will leak if not in same location.
