MF 65 block heater
Tequila
Picked up a 65 with an ugly external coolant heater system
piped off an access port on lower left of block,. I would think
that port was a block drain?? I see a block heater,new, on
eBay but it says for 3/4 inch pipe plug. Freeze plugs are 1-1/4
inch. Anyone had experience with these???
Hi, You can use that by getting an adapter.If MF
still carries it, p/n 677 309 or 191 184m1 or
maybe an auto parts. It has internal 3/4 threads
and an outside shell of 1-1/4(no threads), but fits in hole like a soft plug. This used to be a
common part way back. Chuck
Thanks Chuck,got that all from the local MF dealer. Not sure which Freeze plug accommodates the element length. Anyone out there with one installed in a MF65 A D 4 203 engine block??
