Anonymous-0
hi guys just inquiring about some tractor parts my father has a old massey ferguson 65 and as he is getting along a bit i am wanting to make life on the farm easier so im fixing his tractor up i just put power steering on it and done the tie rods and king pins and clutch but now i am looking for a four wheel drive conversion kit can you help
The only kit I know of was made by Selene in Italy and they are like hens teeth to find. Also they are so scarce that if you do find one it will cost more that the tractor is worth.
Sam
did you buy a new aftermarket power steering kit or did you install an original factory system? what was involed with your install, im interested because i have a massey 50 i was thinking of adding power steering to.....thanks Mike
i brought a second hand original kit that had a worn ram and got a new ram made and put a seal kit through it but you can still buy all the parts brand new it will just cost around $1000
yea on my 50 i beleive i can bolt the ram to the front bolster, it might have the holes there already i thinks. and i have the spot on my engine to mount a pump(got a little steel plate) over it now.
Where did you get the rest of the parts, and where can you buy the parts new? thanks Mike
