Good day! I posted awhile ago about a mystery MF industrial tractor. I have found no ID on tractor other than serial number plate which has a 9A number. This tractor had a Perkins GAS engine, 3 cyl that looks just like the diesel..(but in pcs.) This tractor had 3 speed trans with hi-low range and a shuttle shifter. It has dif lock 3 point hitch, and 2 stage clutch. I can post pictures of what I have later if needed, but it is apart and maybe pictures not that beneficial. It has a simms cab and model 32 MF loader. It is late enough to have had factory alternator installed. Anyone have any idea as to what it might be? Only tractor I have found in my research on Tractor Data is a model 20 that had a 3 cyl perkins gas, but no other info available.
