Massey Ferguson 202?
Jcip
Good day! I posted awhile ago about a mystery MF industrial tractor. I have found no ID on tractor other than serial number plate which has a 9A number. This tractor had a Perkins GAS engine, 3 cyl that looks just like the diesel..(but in pcs.) This tractor had 3 speed trans with hi-low range and a shuttle shifter. It has dif lock 3 point hitch, and 2 stage clutch. I can post pictures of what I have later if needed, but it is apart and maybe pictures not that beneficial. It has a simms cab and model 32 MF loader. It is late enough to have had factory alternator installed. Anyone have any idea as to what it might be? Only tractor I have found in my research on Tractor Data is a model 20 that had a 3 cyl perkins gas, but no other info available.
This is my 'turf 20', the same discription as yours, 3 gas, diff lock, 9A serial number- 1969's I believe.
A 202 wouldn't be a 9A serial number. Does the tractor have a "hard nose" around the radiator? If it does, I am almost certain it is an MF 40 with a model 32 loader but most 40's had the better MF 34 loader. If it doesn't have the hard nose it would be an MF 20 but I wasn't sure the 20 used the 3 cyl gas Perkins. It could have for a few years like the 135 though. A 4 cylinder Continental gas was more common in a 20 but the Perkins is a better engine in my opinion.
