Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: clutch adj. super 90
[Show Entire Topic]  [Return to Forum]
Hymie2lt
09-22-2012 20:39:44
198.254.168.190
Doug
Most times the MP will work in low MP, unless both the low range clutch and high range are warped from heat due to slippage. What happens is the clutch slips due to a poor PS pump, causing heat that warps the clutch. Then when you switch to the other range both clutches will still pull...Causing even more friction and heat.
Usually the high range clutch is the one that warps. I have a neighbor with this problem right now....he can still use it but it is a bit jumpy. We figure it may not be the clutches that warped...but the lip seals on the MP piston may be cracked. We will look at it possibly later this fall.
Using the MP is easy,,,Just put the tractor in the gear you desire, and high or low range. Then swich from low to high MP and back again. All the MP does is give you the ability to get a little extra speed from each of the 8 regular gears and two reverses. Giving you 16 speeds forward and 4 reverse.
One thing I am careful with my MPs is to idle back when shifting from High range 4th to the high range MP. In this gear...and even in third. There is such an immediate increase in speed that the clutch has to slip a bit, unles you clutch, idle down, MP shift, then let out the clutch. It is the same as shifting your standard transmission in your truck. Speed up, clutch, foot off the gas pedal, shift, release the clutch.
Wayne
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
