serial number question
Regis
New User
Hi, just bought a Massey Harris. The guy didn t know exactly the year or model of this tractor. It has a tag on it with numbers 426062. Any idea?
Could you post a picture of it.A couple of questions.What size of motor does it have and what size of tires are on it.Is it a gas engine or a diesel engine.This will give a person some where to start.
thanks for the reply. for the moment, all i have is this tag number. if anyone knows what it means, i d appreciate it. thanks.
1945 Model 81 Standard. Darn good guess, normally Massey Harris serial numbers don't overlap onto other models. I pulled this number off Massey Tractor Data Book. Check the top of the trans just behind your left foot when sitting on the tractor. Serial number is stamped there along with model information.
Scrape the grease and dirt (and maybe extra layers of paint) off top of transmission about where your left foot would go. Most late 40's to early 50's MH had serial number steel stamped into top of transmission. If you find a number there it will tell all. Maybe in 2 line format with top model number like 33G1RF and bottom serial number. Otherwise post a picture and someone can narrow down what it is.
