TractorLinks.com
Show Parts for Model:
Re: T20 Draft Control Spring/Plunger question
MickW
09-18-2012 10:44:52
Hi everyone
I have now managed to replace the plunger with a pattern part (from Sparex.com). I did have to grind the end down a bit as it did not fit very well into the fork on the linkage so that the clevis pin would only go through the assembly when the plunger was at about 30 degree angle.
That is now sorted and the top half is back together. However, I think there is a problem with the control valve as I cannot seem to push it back into the pump and it doesn"t seem to be in the right position to be re-united with the control linkage. Has anyone had a problem with this before? They say a picture paints a thousand words so rather that me going on and trying to explain I have posted up some images in the hope that this may demonstrate the problem and someone may know the solution!
Thanks in advance
MickW
MickW
10-12-2012 10:03:51
 Re: T20 Draft Control Spring/Plunger question in reply to MickW, 09-18-2012 10:44:52
...something I said????!!
MickW
10-12-2012 10:10:55
 Re: T20 Draft Control Spring/Plunger question in reply to MickW, 10-12-2012 10:03:51
by the way I figured out that this was the control valve and that it was stuck out - I managed to drop the pump out and lubricate the valve before putting it back in. I put the whole lot back together and it works, although would you believe I am still waiting for the yoke from Sparex after about 6 weeks (and it's not due for another two). The local blacksmith managed to get the seized part of the plunger out of the yoke but damaged the internal thread in the process and so I am back to square one. Does anyone know what the thread would be so I can try and re-tap it? Looking forward to hearing from you all soon...
