Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Pulling sleeves on MF135 diesel - advice required
[Return to Forum]
CaribooHarry
09-17-2012 21:21:26
64.114.203.53
Having trouble removing sleeves on my Perkins diesel MF135.
Any advice would be appreciated.
[Reply]   [No Email]
Kevin S SC
09-19-2012 18:26:02
64.53.104.141
 Re: Pulling sleeves on MF135 diesel - advice required in reply to CaribooHarry, 09-17-2012 21:21:26
I borrowed a puck made for this from a machine shop. Placed it on the bottom of the sleeve w/ a piece of angle iron and a sledge hammer. Then freezer, light bulb method and puck on top w small hammer to install. Note: the first 1 I thought I would seat it real good, cracked the top lip off quick!
[Reply]  [No Email]
CaribooHarry
09-18-2012 12:54:13
64.114.203.53
We will 'weld out' the liners. I will let you know how it turns out. The mechanic friend doing the work for me has done this a number of times in the past.
[Reply]  [No Email]
Andy Moncman
09-18-2012 07:35:28
64.12.117.17
The safest way is to make a sleeve puller that you can use to remove and install the new sleeves. The cast sleeves crack and the chrome sleeves will buckle and bend. Good luck.
[Reply]  [No Email]
jogl
09-18-2012 05:12:24
64.66.229.212
X2 on the weld method. I just run 4 beads up each sleeve, on quarters. Makes pulling much easier even if you are not doing it in frame. Be real careful not to penetrate the sleeve!
It pays to make up a decent puller too. I had one turned to fit the bottoms of the sleeves. Drilled a 1" hole in the puller and used 1" ready rod to do the pulling.
When you are ready to re-assemble, put the new sleeves in the deep freeze over night. Put a 60W light bulb in each hole over night. Take the sleeves out one at a time and put in the warm block. Have a chunk of hard wood and a hammer handy. I have had them slip right in, no pounding or pressing required doing that. But you have to move quick, those sleeves warm up real fast.
Oh ya, get a couple of cans of brake cleaner and make sure that everything is clean as a whistle.
Good Luck,
JP.
This post was edited by jogl at 05:16:11 09/18/12 2 times.
[Reply]  [No Email]
VTParts
09-17-2012 21:55:36
72.71.201.20
The sleeves are very thin, bring the block to a machine shop to take the sleeves out and press in the new ones. I recently had this done to a perkins 3 cylinder it was less than $200.00
[Reply]  [No Email]
Masseynut(Australia)
09-18-2012 04:31:55
101.162.128.151
 Re: Pulling sleeves on MF135 diesel - advice required in reply to VTParts, 09-17-2012 21:55:36
If you have a suitable puller and "dolly', you may like to try "spatter" welding inside the sleeves before removal.
This method involves using an arc welder at low amps, around 90 amps, and literally running several electrodes, in a circular motion around the inside of each liner from the top to the bottom, inside of each sleeve.
This tends to "shrink" each liner after they have cooled. The result can mean a difference of around twenty tons of force needed to push out the existing sleeve. But don't "hold' the rod in any one place for any length of time. This could possibly weld the liner to the block, ...keep the electrode moving at all times.
You will be surprised at how easy the sleeves will be removed.
[Reply]  [No Email]
DavidP, South Wales
09-18-2012 11:04:32
2.101.99.113
 Re: Pulling sleeves on MF135 diesel - advice required in reply to Masseynut(Australia), 09-18-2012 04:31:55
Hi,
The attached photo shows a puller that I made to remove the liners from a 135 diesel. The bar goes across the bottom of the block and the disc then fits into the top of the liner to pull it in. Ensure that you have the correct liner stand-down for each one. Shims are available if needed.
They should be zero to 004".
When the block bore is fully cleaned and the new liner well oiled they normally fit easily or may even slide in under hand pressure most of the way. Sorry about it being on its side.
DavidP, South Wales
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
