Topic: TO-35 is home
[Return to Forum]
| Author |
[Modern View]
| Inno
09-15-2012 18:49:10
65.95.123.154
Went and picked up the TO-35 that I looked at a couple weeks ago.
The high points
- took the carb from my 202 and a new sediment bowl and she fired right up and sounds pretty good
- Transmission seems to have VERY little wear, much more precise than my worn out 202 which seems to have almost no stops, just kinda point the stick where you want it to go. On the 35 you must make an effort to hit the gear you want.
- No transmission "whine" in any gear, it's especially noticeable on my 202 in reverse and in the low ranges. The 35 has a very quiet transmission
-tires are in pretty reasonable shape, the rears should last a good long time I think, one of the fronts might need replacing sometime soon
The slightly lower points
- clutch needs some adjustment (not a big deal) or maybe with the transmission not being as loose as my 202 I'm just not used to it
- a few minor leaks which I think will be easily fixed
- a minor stutter or miss which I had with my 202 but cleared it up (for the most part) with electronic ign. and a new manifold gasket.
- there is some rust in a few areas, battery box will have to be rebuilt
- governor is not working properly, hopefully just some cleaning and adjustment
- carburetor needs rebuilding (already knew that and bought kit)
- seemed to be burning a tiny bit of oil on initial startup but it hadn't been running properly in over a year so I'm not getting too worried about that just yet.
All in all it look like it either has very low hours or had very good maintenance.
First order of business will be to undress her, remove the loader in it's entirety. While test driving it around the yard this evening I had flashbacks to the way the 202 was before I built the power steering for it, very difficult to control. With the extra weight off and an implement on the back I think it will be a lot better.
Once that is off it will make working on it so much easier.
Pics and maybe a video to follow when I have time.
This post was edited by Inno at 18:50:07 09/15/12. |
| Inno
09-17-2012 19:06:00
65.95.123.154
Re: TO-35 is home in reply to BenAlbert, 09-15-2012 18:49:10
| Quoting Removed, click Modern View to see
Yes, especially since I've seen that you have 3 tractors, or at least I'm pretty sure you posted a picture of 3 of 'em. |
| to_many_irons
09-17-2012 17:09:49
71.7.213.182
Re: TO-35 is home in reply to Inno, 09-15-2012 18:49:10
| with out the loader on the little one will step around a lot eaiser .
the little one front axle is a lot lighter .
both very good tractors . |
| Inno
09-17-2012 10:50:08
206.47.249.247
| It is a decent loader but I have no need of another tractor with loader.......as far as I know. I think I'll "undress" her for now and pretty her up a bit and see how she handles with rear implements in place. If the loader were to stay power steering would be a must. I almost pulled my shoulder out of joint trying to hold on to her on some trails I have with a few small stumps sticking up. I forgot what life was like before power steering. I remembered quickly though!
I may re-purpose some of the loader parts to make a brush grapple for the 202, that is something that would come in very handy for a lot of the cleanup I'm doing.
The battery 2x6 will be gone soon enough once I get a lower profile battery or convert to side terminals. You wouldn't happen to have a spare hood latch kicking around would ya Tony? I believe it should be a push button no? Perhaps that's a small detail I should worry about later.
I have next week off work so I will be doing some work to it and hopefully with it. Might try to get the loader off one evening this week.
With regard to power steering, I think it may get power steering eventually even if I do leave the loader off. The 202 still has it's power steering pump in place although it might be in rough shape. I probably wouldn't need something quite as robust as the system I put on the 202 but we'll see what parts might fall into my lap in the next little while.
This post was edited by Inno at 10:59:19 09/17/12. |
| Inno
09-17-2012 07:13:23
206.47.249.246
| Ya know........I knew there was something different about it but for some reason I couldn't put my finger on it! That's why it's good to post pics on here, many people have a pretty good eye for things.
What I had noticed was when I looked down at the tires from the seat I could see the hub on the right side but not on the left. Didn't put much thought into it after that.
This post was edited by Inno at 10:54:48 09/17/12. |
| 2tractors
09-17-2012 06:22:08
207.144.5.133
| Yo TOOONY what's up with the right front wheel being reversed? |
| Tony in Mass.
09-17-2012 10:07:31
76.127.224.161
Re: TO-35 is home in reply to 2tractors, 09-17-2012 06:22:08
| Elementry my dear watson. The 5 rib implement tyre is too wide to not rub the tie rod end, hence the rim needs to be reversed. Inno should not burden himself with a tractor in such a condition... he should give it to one of us... bah humbug. That's quite unlikely wouldn't you say Watson??? I wonder if all TO35's have a 2x6 on the battery? Mine do... that's a decent loader... maybe another power steering project is in the cards??? |
| 2tractors
09-17-2012 16:57:03
207.144.5.133
Re: TO-35 is home in reply to Tony in Mass., 09-17-2012 10:07:31
| I got the same tires on my standard with no rub. I keep a 2by4 to hold my hood up for battery swaps. I should change my handle to 2batterys. |
| Inno
09-16-2012 18:52:35
65.95.123.154
Re: TO-35 is home in reply to MichiganMH, 09-15-2012 18:49:10
Tony in Mass. said: (quoted from post at 11:34:44 09/16/12)
Well, we've seen TO35's before, and loaders before... so we can wait till Santa brings a new...waterproof? camera...???? |
But you haven't seen my pretty yellow one!
Here it says "special", and it really is special, but I thought with the dual stage clutch it was a deluxe.
Who's a pretty girl?
Just look at that smile!
I took a couple videos with my wife's camera but for some reason it jumps a bit and you don't get a smooth video. I'll try with my blackberry sometime. I sat it beside the 202 for comparison, the 35 looks small in comparison even though it's not really. The 202 is just "beefier". Took a choppy video but didn't think to take any pictures. These will have to do. There is not a hint of red or grey paint anywhere. I believe this one was always yellow. Not in the Kenny Rogers way though.
This post was edited by Inno at 18:54:47 09/16/12. |
| Tony in Mass.
09-16-2012 09:34:44
76.127.224.161
| The doggie dish! That sounds too real to be made up! Hey the dollar store kinda places down here - big lots? Had JAZZ snapshot and video cameras for $25, first didn't last too long, told the manager and she gave me another that holds up good, but goes thru batteries, it's not a rechargeable in the camera. Well, we've seen TO35's before, and loaders before... so we can wait till Santa brings a new...waterproof? camera...???? |
| Inno
09-16-2012 08:15:28
65.95.123.154
| MY camera was dropped into one of the dog's water dishes a few months back by my daughter.
Yes we have other cameras but after having gone on our anniversary to look at the tractor then going yesterday for the day to pick it up there are a few other things which take priority over getting tractor pics on the internet..........but believe me, it's weighing VERY heavy on my mind! |
| Tony in Mass.
09-16-2012 07:37:44
76.127.224.161
| And your camera is where????? This is mean to keep us hanging like this... |
| avd123@live.com
09-16-2012 07:37:05
76.127.224.161
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
