| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: PTO leak
[Return to Forum]
| Author |
[Modern View]
| NCMau
09-13-2012 06:37:14
174.110.228.151
My 202 has an annoying PTO oil leak. I am having difficulties in locating the proper seal. Can you steer me in the right direction?Looking in my limited service manual, looks like just removing the bearing retainer, the shaft should slide right out without complications, right? If I don't have to replace the bearing, do I need anything else beside the seal and the O ring? |
| sam40
09-16-2012 17:22:37
81.154.213.101
Re: PTO leak in reply to NCMau, 09-13-2012 06:37:14
|   Here is a picture of the correct seal (top right) the others are what the previous owner fitted to try to stop the leak. The seal should be available from Sparex. Second pic is the power shaft ready to remove using the method explained by DavidP, Strip off all collars etc and then the ring/housing around the shaft will pull out with the shaft. Remove a snap ring and drive out the seal ,fitting is a reverse process but don't damage the seal metal housing. turn the shaft back and forth to align the splines on refitting. Sam |
| NCmau
09-14-2012 07:39:32
174.110.228.151
Re: PTO leak in reply to Laneman, 09-13-2012 06:37:14
| Quoting Removed, click Modern View to see
That's a great idea, David P. Now if I only can locate the seal I have made. Thanks. |
| DavidP, South Wales
09-13-2012 13:09:13
2.101.102.6
| Hi, You reak may be caused by grass wrapped around and inside the dust lip in the seal. There may also be wear or pitting in the area that the seal lip runs on. A repair collar should be available for it. This is a very thin bush that slides over the shaft and provides the seal with a new face. Although it is only the O ring that holds the housing in place they can be difficult to remove due to rust and debris around them. Ihave a slide hammer with a cup which fits over the end of the shaft and is retained for removal by a 5/16 bolt through the cup and radial hole in the shaft. The yoke from a drive shaft can be fitted and suitable pry bars used on each side to lever it out. Replacement of the seal is simple using suitable large sockets or tube. DavidP, South Wales |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
