toddol1971
New User
my massey 65 g176 continental is slowly getting hot. It can idle all day just fine, but start bushhogging and the temp goes up. It has even died a time or two. Here is the things I"ve done so far. I had the rad cleaned about 10 years ago. Maybe 800 hrs since. change antifreeze every 3 or 4 yrs. New water pump 6 yrs ago. flushed out system 3 times last month and took the t-stat out. it still gets hot. I changed the spark plugs and while out I looked in the holes and the piston and cylinder look gunky. No water that I could see. no water in oil and no oil in water. I did a comp test 175/175/154/175. I pulled the fan and straightened the blades (they weren"t really that bad, I figured what the heck worth a shot). . New rad hoses. The only thing I haven"t done is check the timing. I need to do it. which way advances it? cw or ccw? So, what do youns think? Any ideas? Thank You.
