TractorLinks.com
Show Parts for Model:
Re: 230 Water Pump Question
DavidP, South Wales
09-06-2012 08:22:36
Hello,
The pulley is pressed on and as Bob has said should come with a new pump. The position of the pulley on the shaft is important for belt alignment. If you should be overhauling a pump you will need a puller to remove the pulley after you have noted its exact position. You will also need a press to remove the bearing assembly and refit the impeller.
DavidP, South Wales
