Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Sinking 3pt Lift
09-05-2012 19:07:31
the 3 point should be controlled by the 2 levers between the seat and fender one is draft the other is position, the 2 in front of the seat are remotes that are supplied by the 3 point lift pump, only the remotes or 3 point control can be supplied at one time,if the remote control is raising the 3 point up and down something is set wrong or the remote valve has a problem
09-05-2012 21:04:38
 Re: Sinking 3pt Lift in reply to gbs, 09-05-2012 19:07:31
According to my manual on the auxiliary hydraulics the #1 valve controls the three point lift. You can set the levers on the side of the seat to constant pumping and use the aux. valve or lock the aux. valve in the up position and use the hydra levers beside the seat. I bought a mf65 with the aux. valves but it has a bad pump in it. I want to take the valves off of it and put on my mf50. I just haven't done it yet. I do need to get it done and then I can get a better understanding of it.
