| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Massey-Ferguson 135 Hydralic Cylinder Cracked
[Return to Forum]
| Author |
[Modern View]
| Ed W.
09-05-2012 16:10:42
168.17.16.214
First, the rear bolts into the hydraulic cylinder sheared, then I fixed that problem. Then I put it all back together and all worked fine. I pulled the lift all the way back to the aux position, because I did not think it was as high as it should have been, popped again. This time when I took it apart it had cracked the cylinder. I normally just mow with this tractor, some garden work but not much. I noticed that the top link had vibrated all the way out. Could this have caused this? I have a new cylinder ready to install, but I don't want to tear this one up also. |
| Ed W.
09-06-2012 10:57:52
168.17.16.214
Re: Massey-Ferguson 135 Hydralic Cylinder Cracked in reply to Ed W., 09-05-2012 16:10:42
| | Thank you all so very much! I will be looking for a pressure relief valve and some tools! Ed |
| DavidP, South Wales
09-06-2012 02:16:09
78.148.49.33
| Hi Ed, It is essential to have the correct special tools to carry out the hydraulic adjustments. More importantly is the fact that the linkage must NOT lift and jam otherwise it can break the cylinder as you have found. At full lift you must ALWAYS be able to lift it a little higher by hand. The settings put the pump into neutral to give the safety zone. DavidP, South Wales |
| gbs
09-05-2012 18:41:08
68.115.197.190
| unless you have access to the special tools needed to adjust the lift you will be time and money ahead to take it and get it set before reinstalling it, then you will need the gauge to set the response control with after you get the lift back on the tractor before you install the response control cover,learned that the hard way |
| JerseyJoe
09-05-2012 18:09:14
74.90.145.6
| Ed,before you waste more money and time,replace the pressure relief valve.It is located on the pump.I learned the expensive way.LOL |
| Masseynut(Australia)
09-06-2012 03:46:14
123.211.30.253
Re: Massey-Ferguson 135 Hydralic Cylinder Cracked in reply to JerseyJoe, 09-05-2012 18:09:14
| Jersey has nailed it, replace the relief valve ASAP. Even if the adjustments are out of whack, the new valve will save you from re-visiting this problem again. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
