TractorLinks.com
Show Parts for Model:
Re: 20f dual clutch mess
DavidP, South Wales
09-04-2012 07:08:48
Hi,
As Tony has said look at the clutch plate to check if you have it in the wrong way round. Some can be fitted incorrectly. I'm not sure which type of clutch unit you have in your tractor so as a general reply; have you removed the 3 slave screws from the cover (if fitted)?
Do the springs appear to be coil-bound? It's not uncommon for the release levers to 'flattish' on a new assembly. Have you checked the depth of the flywheel ledge against your old flywheel?
Have you set the height of the screws in the end of the release fingers (if fitted)correctly?
Have an assistant operate the clutch pedal whilst you observe the operation.
DavidP, South Wales
