I am needing some help with my 3pt lift. It has no problem when lifting light weight implements such as a hay lift (for round bales). The problem seems to be when I attach heavier implements or try to pick up round bales. The implements that I am using are from a 425 Ford Workmaster that I had before the 65 and did not have any problems with it, so I wouldn't think that the 65 would have any problem. I'll try to attach some pictures and /or videos to help. I am hoping that it will be something minor/simple that I can work on instead of having to put it in the shop.Any help is greatly appreciated.
Model: MF-65 w/ Multi-Power
Engine: Perkins Diesel
Year: 1964
S/N: CNDW 705874
http://www.youtube.com/watch?v=wRg9qobI8ls
http://www.youtube.com/watch?v=xHthl4nZpiA
F.Y.I. When the hydraulic valve is pushed forward, the lift goes down and when the valve is pulled back, the lift comes up.
Year: 1964
S/N: CNDW 705874
