TractorLinks.com
Show Parts for Model:
Re: T20 Draft Control Spring/Plunger question
Jason S.
09-03-2012 05:03:36
Well...you can drain a few gallons of oil out of the hydraulic system and then remove the round cover with the dipstick where you check the hydraulic oil and take a look inside and see what's happening. First check that the control valve linkage is working back and forth when you move the draft control lever beside the seat. Then check to see that the control valve itself is in the linkage. It's in the very bottom of the pump so you won't be able to see it unless you completely drain the hydraulic sump...but you can feel for it. The end of it where it hooks into the linkage is T shaped. If you don't completely drain the hydraulic system then you can crank the tractor and look inside for leaks in the system. Check the linkages first because even with the spring out of adjustment it should still lift and lower some. Did you try to tighten plunger before this happened?
