TractorLinks.com
Show Parts for Model:
T20 Draft Control Spring/Plunger question
MickW
09-02-2012 05:10:46
Hi All
New here and looking for some advice please?!
I am in the process of replacing the draft control plunger and yoke on my newly acquired T20 which was seized up and had so much free play that it was flapping about like a sock in the wind!
I have looked at the manual and it says that these parts have to be replaced as a matched pair does anyone know anything about this? I have found a company that does replacements but these are sold separately, so I am assuming that they will not be matched.
Also would it be advisable to replace the spring or is it okay to re-use the original (which looks absolutely fine)?
Thanks in advance for any advice you can give on this procedure!
All the best
MickW
MickW
09-18-2012 10:44:52
 Re: T20 Draft Control Spring/Plunger question in reply to MickW, 09-02-2012 05:10:46
Hi everyone
I have now managed to replace the plunger with a pattern part (from Sparex.com). I did have to grind the end down a bit as it did not fit very well into the fork on the linkage so that the clevis pin would only go through the assembly when the plunger was at about 30 degree angle.
That is now sorted and the top half is back together. However, I think there is a problem with the control valve as I cannot seem to push it back into the pump and it doesn"t seem to be in the right position to be re-united with the control linkage. Has anyone had a problem with this before? They say a picture paints a thousand words so rather that me going on and trying to explain I have posted up some images in the hope that this may demonstrate the problem and someone may know the solution!
Thanks in advance
MickW
MickW
10-12-2012 10:03:51
 Re: T20 Draft Control Spring/Plunger question in reply to MickW, 09-18-2012 10:44:52
...something I said????!!
MickW
10-12-2012 10:10:55
 Re: T20 Draft Control Spring/Plunger question in reply to MickW, 10-12-2012 10:03:51
by the way I figured out that this was the control valve and that it was stuck out - I managed to drop the pump out and lubricate the valve before putting it back in. I put the whole lot back together and it works, although would you believe I am still waiting for the yoke from Sparex after about 6 weeks (and it's not due for another two). The local blacksmith managed to get the seized part of the plunger out of the yoke but damaged the internal thread in the process and so I am back to square one. Does anyone know what the thread would be so I can try and re-tap it? Looking forward to hearing from you all soon...
MickW
09-11-2012 14:22:05
I wish I had tried that but instead I put a big bar on it and turned it until it sheared off! I have bought a new plunger and yoke but disappointingly the suppliers don't stock these pins...the search continues!
Will keep you posted - the list of jobs for the Fergie grows by the day :o)
MickW
09-11-2012 10:56:40
 Re: T20 Draft Control Spring/Plunger question in reply to Olen (TN), 09-02-2012 05:10:46
Hi all
To answer Jason's question I did try to tighten the yoke to take up the play, but it was seized solid!
Since my last post, I have noticed that the cleavis pin securing the plunger to the fork is badly worn and needs to be replaced, but I have had a hell of a job trying to track one down. This pin is 3/8" dia and about 1 5/8" in length - does anyone know a place that stocks these?
Thanks in advance
MickW
Jason S.
09-11-2012 13:06:39
 Re: T20 Draft Control Spring/Plunger question in reply to MickW, 09-11-2012 10:56:40
You won"t get the yoke to turn until it is heated cherry red with a torch...it"s been on there too many years with out oil or grease....most all of them are that way. The last pins I bought I got from a bolt supply shop...a few times I have had to cut them off and redrill the holes because they were too long.
MickW
09-03-2012 01:04:51
Hi Jason
Will do! The one I took off must have had about 1/2 inch freeplay and of course it was not doing its job at all.
The other potential problem I have is that the hydraulics had just completely packed up whereas it was lifting and dropping before. Is there anything obvious I can check for before I replace the draft control assembly and put it all back together?
Thanks for your help and advice
MW
Jason S.
09-03-2012 05:03:36
 Re: T20 Draft Control Spring/Plunger question in reply to MickW, 09-03-2012 01:04:51
Well...you can drain a few gallons of oil out of the hydraulic system and then remove the round cover with the dipstick where you check the hydraulic oil and take a look inside and see what's happening. First check that the control valve linkage is working back and forth when you move the draft control lever beside the seat. Then check to see that the control valve itself is in the linkage. It's in the very bottom of the pump so you won't be able to see it unless you completely drain the hydraulic sump...but you can feel for it. The end of it where it hooks into the linkage is T shaped. If you don't completely drain the hydraulic system then you can crank the tractor and look inside for leaks in the system. Check the linkages first because even with the spring out of adjustment it should still lift and lower some. Did you try to tighten plunger before this happened?
Jason S.
09-02-2012 15:25:28
Carefully compare the one you buy with the original plunger. I have heard some of the replacements are longer and the end may have to be cut to get it to the same length of he original. Your original spring should be fine...once you get it back together...hook it to a 2 bottom plow and when it's lifted you should have about .020 clearance between the plunger and the spring...or be able to turn it by hand. If there is more than that the draft control may not work correctly.
MickW
09-02-2012 14:50:13
 Re: T20 Draft Control Spring/Plunger question in reply to Dieseltech, 09-02-2012 05:10:46
Hi Sam
Thanks for the info - will give it a go and let you know how I get on
Best
MickW
samn40
09-02-2012 13:05:37
You can buy and use the individual parts so long as the threads match. The old spring should be fine. Tighten the spring until it can just be turned by hand. Sam
