| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: MF 40 Power Steering
[Return to Forum]
| Author |
[Modern View]
| nosteer
08-28-2012 17:27:29
68.90.8.46
Does anyone have a clue as to why my tractor won't steer" After removal of the pump and replacing the shaft seal, I have topped off the fluid several times and the only way it works is to keep rotating the steering right and left many times then it will catch and work a short while. Then I rev the engine and do the steering wheel rotation and it catches again, but only for a few seconds. I have the Plessey type pump. |
[Reply] [No Email] | |
| MKinOntario
08-29-2012 18:50:04
69.158.114.105
Re: MF 40 Power Steering in reply to nosteer, 08-28-2012 17:27:29
| It takes a very long time and a lot of fills to get all the air out and the system topped up if it was really empty. Lift the front wheels off the ground while you turn back and forth. It will help. Turn it completely from left to right and back, but don't run up against the stops. If this doesn't do it, there are other problems. Did it work OK before the pump seal replacement? If so, it's likely just low fluid. |
| nosteer
08-30-2012 04:58:37
68.90.8.46
Re: MF 40 Power Steering in reply to MKinOntario, 08-29-2012 18:50:04
| Thanks for your info. I will surely try that and yes it worked fine before the repair. I'll get back. Gary |
| DavidP, South Wales
08-29-2012 02:15:50
2.97.132.66
| Hello, As a general answer to your question; Not sure which type of PAS you would have but its likely to be the hydraulic cylinder acting on a shaft on a pedestal in front of the radiator. If it is, remove the front grille. Have an assistant work the steering wheel back and forth and check all linkage, ball joints etc from the steering box forward. Look for any wear in the balls or bushes etc. When you get to the cylinder it will have a spool valve mounted on it. This spool valve must move back and forth before you try to move the main steering linkage. This gives you hydraulic activation. If you don't have this spool movement you will be on manual steering. There is an adjustment to control the amount of movement on the spool but there should be no play or wear anywhere else. DavidP, South Wales |
| mike paulson
08-28-2012 20:23:10
98.15.179.173
| sounds like something came apart in your steering gear/box. when you turn the steering wheel and it freewheels as you described does the steering linkage move? |
| nosteer
08-29-2012 15:18:30
68.90.8.46
Re: MF 40 Power Steering in reply to mike paulson, 08-28-2012 20:23:10
| No, It's all hydraulics. The control that is attached to the steering wheel has 4 hyd hoses connected to it. I thought the problem was air in the hyd system but I have refilled it over and over using the instructions in the manual. The steering wheel goes from free movement to rather hard movement. All at once, the system works and will keep working as long as I keep the steering wheel moving R_L or L-R. If I stop, then it quits working again. When It is working, the steering turns relatively easy.The only mechanical linkage is the tie rod. It has a left and right cylinder that is driven by the pump thru the control unit under the steering wheel Thanks for your input. Gary |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
