| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: 135 multi power
[Return to Forum]
| Author |
[Modern View]
| robert vanderstar
08-26-2012 18:33:15
204.101.75.105
I am going to look at a 1968 6 speed 135 continental gas with multi power. How can I tell if it is working properly or at all? What does the multi power do and how does it do it? I have some problems with my 2705's powershift so I am a little cautious. How often do the MPs break and can they be set in high or low and left there? |
[Reply] [No Email] | |
| Fergie Bach
08-27-2012 03:12:06
78.150.252.172
Re: 135 multi power in reply to robert vanderstar, 08-26-2012 18:33:15
| In the UK MP is often avoided as it has had issues on higher hours tractors. It is expensive (and or time consuming) to repair although if working correctly is a useful addition to the machine . The additional pump means a higher rate of hydraulic oil delivery too, which could be useful for some modern hydraulic equipment.That the tractor cannot be pull started in an emergency is a negative aspect as is it"s lack of engine braking in "low" especially if you live in steep hilly country. For most hobby owners it"s biggest advantage is higher road speeds. Personally I would want plain old working reliability and would avoid it. |
| cropspray1
08-26-2012 19:22:47
206.246.13.118
| The Multi power is a Hydralic High and low which can be activated " on the go". There is only engine braking while in the High side which means the tractor will free wheel in low.The MP has been a very good option since they have been used on all Massey ferguson tractors since 1963.If they fail they are normanly in low. I have several MF tractors and I prefer MP transmissions. |
| robert vanderstar
08-26-2012 19:34:32
204.101.75.105
Re: 135 multi power in reply to cropspray1, 08-26-2012 19:22:47
| thanks cropspray, do you know where in the gear train the unit is and if it can be activated externally? Can it slip or if it works it is fine? Can it be used continuously or meant for occasional or low power use? Can it be removed or bypassed in the event of problems? My 1975 135 UK diesel serves me weell without it! |
| robert vanderstar
08-27-2012 06:11:29
204.101.75.105
Re: 135 multi power in reply to robert vanderstar, 08-26-2012 19:34:32
| Can the tractor be pull started if left in high when shut off or is the tractor basically in neutral when shut off? I would hate to rely on the parking brake alone! Rob |
| DavidP, South Wales
08-27-2012 09:23:51
2.100.118.3
Re: 135 multi power in reply to robert vanderstar, 08-27-2012 06:11:29
| Hello Robert, The auxilliary pump provides hydraulic power to the MP clutch pack to provide drive when the engine is running. As soon as the engine stops hyd power ceases and the pack becomes inoperative. The answer to your question is that there is no engine braking when the engine is switched off so you will be dependant on the parking brake. After 40 years of MF experience I am still a fan of MF but it is something that must be used correctly. It should not be used in 'low' for extended periods. This is not the intention as you should always use the highest gear possible for the job at hand. If used in low for extended periods it should be moved to 'high' occasionally to lubricate the plates as they can run dry, warm up and wear. As Fergie Bach has said they can be expensive to repair but once done should last a long time. If you have a combining valve fitted you will be able to achieve an increased oil flow but your maximum pressure will be 2000psi, that which the aux pump relief valve is set to. Being able to do this will depend on whether auxilliary hydraulics are fitted in having a dual element pump. DavidP, South Wales |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
