Super 90 flywheel markings
P.Malin
New User
I have a Massey Ferguson Super 90 Diesel with Multipower trans. The techs are leaning toward changing the trans over to a standard transmission instead of the multipower. They report needing a different flywheel than is on it now. I located another flywheel, but need to know if it is correct.
The markings on it are, HD277C4090 and E20-1 and MF 1 .
Since it has HD277 on it I would say it may be from an 85 diesel ( older variant of the 90 )which had the 277 Continental in it. I'm not sure what the casting number on the Perkins engine would be.
P. Malin
The flywheel you need is part # 733879M91.
It is the same as the flywheel on 410 diesel combine.
Tom Dold
Dold Implement
201 S. Main St.
PO Box 70
Howard, SD 57349
605-772-4541
[email protected]
