Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: '67 MF 135 charging question.....
[Return to Forum]
Bobinva
08-26-2012 07:38:53
108.48.43.190
My 135 (Z145 Continental) has a 12 gen...starts great, the ammeter needle drops to slight discharge as starter turns over, once running (never more than a full rotation), the needle comes back to dead center and doesn't go to "charge" unless I turn on the headlights...after a couple seconds, it will charge...when its "done", needle drops back to dead center and will not charge again untill I turn on the lights again...VR contacts dirty???/ Any help appreciated. Bob in VA
[Reply]   [No Email]
Tennessee Kid
08-28-2012 21:44:36
68.184.170.221
 Re: '67 MF 135 charging question..... in reply to Bobinva, 08-26-2012 07:38:53
I've got a 1965 Z145 that the tachdrive was shot, no cable. Dynamo worked, but wanted all the gauges working. Found a dealer on eBay selling a GM three wire Alternator w/tachdrive for $179. I went that route. Replaced the ampmeter with a voltmeter. Replaced the proofmeter. It was froze up with rust. It's a more troublefree setup with an alternator which was what I was wanting to achieve.
[Reply]  [No Email]
Bobinva
08-26-2012 15:08:52
108.48.43.190
 Re: '67 MF 135 charging question..... in reply to OldMoIron, 08-26-2012 07:38:53
Maybe you folks didn't understand what I was trying to say...1. Generator is putting out fine..had it checked out at auto electric place...2. Battery is completely charged and stays that way when I do what I said in the first post...3. VR (original to the tractor) charges when I put a load on the unit....ie. turn on the lights. 4. Yes, I flashed the generator to the battery side of the VR.... My question still is why doesn't it charge right after I start the engine ...again...could it be the contact points in the original VR? Bob in VA
[Reply]  [No Email]
chas
08-26-2012 23:00:58
93.23.201.39
 Re: '67 MF 135 charging question..... in reply to Bobinva, 08-26-2012 15:08:52
The old type regulators are generally serviceable, even if they look 'sealed'. Common problem is tarnished / burned contacts, even 'New-Old Stock' replacements can have problems from years on the shelf . If you email me direct I can email you a service sheet that may help. (too big to post on here).
Regards ..... chas
[Reply]  [No Email]
Jason S.
08-26-2012 09:50:39
174.254.196.6
I have to agree with the cheap voltage regulator statements.
My 175 wouldn't charge and I tried one the cheaper voltage
regulator and it wouldn't charge. I went to oreillys and ordered
a Borg Warner select voltage regulator and it started charging
and hasn't given me anymore problems. The cheaper ones
instead of having contact points in them they have a solid state
circuit board and they just don't work. If you go buy one and it
isn't as heavy in weight as your original or if you don't see the
resistors on the back of it like the original...I wouldn't buy it.
Have you polorized the generator to see if that makes a
difference?
[Reply]  [No Email]
samn40
08-26-2012 09:27:23
81.135.24.245
Try removing the + lead from the battery with the engine running,
if it is a gas engine it should still run if the dynamo is charging, on
a diesel the lights ahould still work with the +terminal
disconnected.
Sam
[Reply]  [No Email]
maxwell99
08-26-2012 08:11:58
208.78.252.250
repair cycle i use:
1. Charge battery up to full charge, then take it you a battery shop or parts store that has the battery test equipment taht can place a load on the battery and determine the condition of the battery.
note to file: a bad battery will give you all kinds of problems with your charging system, you must have a good battery.
2. generator test, if you cannot do the test then have it done by shop, but the generator must be working properly
3. VR test: when starting needle goes to (-)
then after starting needle goes to (+) for a short while until battery is topped off.
full charge.
turn lights on, flashers on if you have then and idle down, needle should go to (-) then speed up motor and needle should go to (+)
(if it does not work this way)
all i have been able to do is replace VR, these new one's are made off shore and cheap, most do not allow for any adjustment. Just replace the VR with the best quality VR you can afford.
#####most people like to get rid of the generator/VR setup and go to a alternator with build in VR as all cars/trucks/tractors have today.
but my old generator has the gearbox on the back that runs the tach, but you can buy tacks that run off the coil and eliminate the geardriven generator.
good luck,
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
