| Author |
[Modern View]
| Chip812
08-14-2012 10:54:04
216.226.180.3
For a MF35... Just the MF35 (oh, and the bush hog too, I suppose)... 12x20 big enough? |
[Reply] [No Email] | |
| Aaron Ford
08-17-2012 17:37:07
76.92.68.163
Re: What size pole barn... in reply to Chip812, 08-14-2012 10:54:04
| | Fella once told me that you could roof over your entire property and not have enough. Push your limits as far as you can. Never heard a fella say, "Dang, my stuff is too dry. Wish I had built this smaller..." My 10x12 is now 16x16. Aaron |
| WY JERRY
08-16-2012 13:58:16
72.21.72.104
| My 40 x 70 is full and I have stuff outside (again)... |
| FBH44
08-15-2012 14:45:30
64.85.221.16
| Yep, build it twice as big as you think. At least setit up so it can be added onto. I did building inspections for 20+ years, and never saw one built that was big enough. Includijg outbuildings, garages, Supercenters, schools... |
| Chip812
08-15-2012 07:39:36
216.226.180.3
| Holy Smokes... You guys are killing me... It is just going to be 'covered' parking for my little MF35 and it's bush hog... :lol: |
| rustyplow
08-15-2012 15:10:50
75.51.123.230
Re: What size pole barn... in reply to Chip812, 08-15-2012 07:39:36
| And you have nothing else that you would ever want to put inside under cover? When sizing a shed, put everthing that you want to put in it togeather in one spot. Now take that size and double it. Next build in a place that can be added on 3 times. And your still out of room in 2 years. ;-) |
| Dave_Id
08-15-2012 09:01:05
75.92.58.173
| Build it as wide as you can afford. You can always add to the length later. For instance, 36 wide x 24, then add another 24 or 36 to the length later. |
| petebac
08-15-2012 13:56:53
96.61.144.220
Re: What size pole barn... in reply to Dave_Id, 08-15-2012 09:01:05
| When I built mine 24x40 I thought wow all kinds of room, it"s now full and I need more room. |
| jf
08-15-2012 06:27:38
173.24.65.111
| I was told way back when, in buying a boat, camper, trailer or building a shed-go bigger than you think you will need. A 12 x 20 sounds big now, but by the time you get all the other "stuff" you will get its going to get real small real quick. |
| john65
08-15-2012 06:18:25
67.253.253.8
| build it as big as you can afford!!!!i got a 50x100 and i need 100x200 |
| Inno
08-15-2012 05:58:31
206.47.249.246
| 12x20 sounds a bit on the small side. At least double the smallest dimension. My garage is 24x36 and it's just barely deep enough, an extra 4' of room would be (almost) perfect. |
| 2tractors
08-15-2012 05:22:28
207.144.5.133
| After my divorce and move left me pennyless and p=--yless I bought an old barn, tore it down and moved to my new location. It started out as a pole barn and now is enclosed with cement floor. I need to put leantoos around to shelter all the junk!! |
| arch in ky
08-14-2012 16:32:02
71.31.5.42
| The size I think would work and than doulbe it.I have hear that When building a store church you should go doulbe what you think you need,. |
| Diydave
08-14-2012 16:16:08
96.244.155.63
| Build it round, that way you can't throw sh!t in the corners! |
| petebac
08-14-2012 12:05:12
96.61.144.220
| When I built my garage and pole barn I thought that they would be big enough but now I wish I would have doubled the size. |
| mike paulson
08-15-2012 14:45:06
98.15.187.200
Re: What size pole barn... in reply to petebac, 08-14-2012 12:05:12
| polebarns and barns are no longer cheap to build. build what you can afford, plain n simple. |
