| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: MF 35 hydraulic lift problems - need help
[Return to Forum]
| Author |
[Modern View]
| rveach
08-10-2012 13:45:10
67.238.197.55
I just put in a new hydraulic pump, ram piston, and ram piston rings in my MF35 Deluxe. All new from AI Products. Now my gear oil foams and I get no lift. It tries to lift, but there is no pressure.I took off the stand pipe cover and fluid is flowing up the tube but its not building any pressure. I get some fluid dripping from the opening of the ram cylinder but not as much as is coming up the standpipe. What did I miss? |
| Inno
08-13-2012 15:00:40
206.47.249.246
Re: MF 35 hydraulic lift problems - need help in reply to rveach, 08-10-2012 13:45:10
| The adjustments are best done with the lift off for sure.......I'm a lefty too and I don't really think that has too much to do with it. You need a spring scale with small increments, I used a fish weighing scale I had in my tackle box. You adjust the nuts so that when the levers are in a certain position, it takes EXACTLY 3lbs of pull to make the control arms hit the back of the bracket..........it'll make sense once you have it off, I (almost) promise........I'm very careful with promises.
John (UK) has a very good set of written instructions which I for some reason can not find on my computer anywhere. You can send him an email or holler for him over on the Harry Ferguson forum. He'll email them to you. |
| Tony in Mass.
08-11-2012 14:27:14
76.118.216.103
| If you refer back a few days, you will find my post on almost the same problem., Well, you got some serious foaming... carbonating affair gong on, not mine, but... I finally got into the porthole, pushed the pump's roller with my finger- the long tapered lever hitting the roller isn't going rearward far enough- 3/8 to 1/2 shy of a good strong lift of the rock shaft.. Not a fluid issue, nothing expensvie broken, but I bet both of us are going to have to adjust these levers to do the job. I am expecting the cover is going to have to come off. |
| rveach
08-11-2012 17:39:56
67.238.197.55
Re: MF 35 hydraulic lift problems - need help in reply to Tony in Mass., 08-11-2012 14:27:14
| | I took the top cover off today and I think I made it worse. I just dont understand how to do the adjustment. There are two spring loaded adjustment screws one for draft and one for the control lever. Yesterday, before taking off the top cover I tightened the nut on the control lever and it went back far enough to operate the control value. Today I messed with the draft screw and then I had to loosen the control lever nut to make the control lever go back. So one day tightening makes it go back and the next loosening makes it go back! Oh, and I took the top cover off because I dropped my socket wrench under the pump. You can adjust those nuts without taking off the top cover with a 1/2" socket on a 1/4" drive ratchet, but tie a string to your tools! |
| Tony in Mass.
08-11-2012 18:56:23
76.118.216.103
Re: MF 35 hydraulic lift problems - need help in reply to rveach, 08-11-2012 17:39:56
| Yep, my day didn't go any better. But I bought the DVD on massey hydraulics from the online store here, came in a couple days, atleast you can watch it over and over, and I am reading that chapter on every MF repair manual I have, but I just couldn't get anything done thru the porthole- being left handed didn't help- but I believe my problem is further back having to do with the ferguson system spring.... but I am thinking about welding a little tab to the lever that is suppose to push the pump roller further back. But I will try going by the book, just to teach myself how to do it.. by the book... |
| miner09
08-10-2012 20:24:50
75.227.190.202
| Are you using a 90w--GL5 oil. I'm not sure if this is correct for the 35,(look at top filler plug) manual should show right oil. May be reason for the foaming. |
| rveach
08-11-2012 05:03:36
67.238.197.55
Re: MF 35 hydraulic lift problems - need help in reply to miner09, 08-10-2012 20:24:50
|  90w GL1. I'm thinking the foam was from the air in the new components. Maybe? |
| rveach
08-10-2012 17:26:36
67.238.197.55
Almost fixed in reply to rveach, 08-10-2012 13:45:10
| OK, the "problem" was pretty simple. The operators control lever wasnt opening the control value on the pump all the way. I needed to adjust the lever. So now I have full pressure (2500 PSI) and the lift works; however, the operating lever only actuates the control valve in the last two or so inches of travel. Is this normal? I'm used to having more throw in the lift lever but I've never used a MF35 before. |
| rveach
08-10-2012 13:49:22
67.238.197.55
| rveach
08-10-2012 13:46:37
67.238.197.55
|  Oil |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
