Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Need help with MF65 steering shaft bearing
[Return to Forum]
will78
07-25-2012 15:19:04
70.100.76.79
I ordered bearing #1850526M91 for my MF65, and it seems to large to fit in my steering housing. Also the center of the bearing is so large that my snap ring wont hold it on the shaft. My tractors serial number is 673426. Everywhere I search it says this is the correct bearing for my tractor. But it definitely wont fit, so what am I missing?? I actually tried using my old bearing but its in too bad of shape. And I havent disassembled everything yet to measure my old bearing cup. Everything was cleaned and there was nothing to foul the bearing and keep it from fitting in.
[Reply]   [No Email]
will78
07-27-2012 20:11:31
70.100.76.79
 Re: Need help with MF65 steering shaft bearing in reply to will78, 07-25-2012 15:19:04
Well I picked up a bearing today from napa autoparts for $11.00. It wasnt an exact fit, bit after shaving down the O.D. of the race it fit perfectly. Also had to build my steering shaft up to match the I.D. more closely.
It was well worth it in order to save $160!!! 8)
[Reply]  [No Email]
2tractors
07-28-2012 05:06:18
207.144.5.133
 Re: Need help with MF65 steering shaft bearing in reply to will78, 07-27-2012 20:11:31
Glad to hear you found a way around the outragous cost. I have a power steering sector that needs 300 worth to fix.
[Reply]  [No Email]
2tractors
07-26-2012 05:40:08
207.144.5.133
The power steering units on a 35 have a larger shaft and larger bearings, maybe that's where the mix up is.
[Reply]  [No Email]
will78
07-26-2012 05:43:28
70.100.76.79
 Re: Need help with MF65 steering shaft bearing in reply to 2tractors, 07-26-2012 05:40:08
2tractors said: (quoted from post at 05:40:08 07/26/12) The power steering units on a 35 have a larger shaft and larger bearings, maybe that's where the mix up is.
Thats how it seems, the bearing is alot larger then my old one, inside and outside diameter both.
Originally the bottom bearing was in good shape, but the top bearing wasnt. I even tried switching them around (thats why the top bearing looks good in the pics) but as soon as I tried it the balls jumped out of the bottom one, they are worn down and the bearing cup has small pieces busted off it.
This post was edited by will78 at 05:48:18 07/26/12.
[Reply]  [No Email]
Masseynut(Australia)
07-25-2012 23:37:18
143.238.162.25
Are you sure the box is an original for that model? Reason I ask is that there is no snap ring in the worm shaft, retaining the bearing in place, on the MF65 steering box.
The ball race is sandwiched between the outer cup, and the profiled section of the worm shaft.
Can you post a pic or two of yours? It may help us identify it for you,
Evan.
[Reply]  [No Email]
will78
07-26-2012 05:41:37
70.100.76.79
 Re: Need help with MF65 steering shaft bearing in reply to Masseynut(Australia), 07-25-2012 23:37:18
Honestly I have no idea if its the origianal one. It doesnt appear to have ever been changed, but with this old tractor who knows haha!
I'll post some pics.....
This post was edited by will78 at 05:46:13 07/26/12.
[Reply]  [No Email]
will78
07-25-2012 16:08:15
70.100.76.79
Well I took everything back apart and pulled out my shaft. And the ball bearings had already fallen out into the housing. So I measured the old bearing cup and its roughly 2-3/8" OD. And the ID is 1-1/2". I guess Ill have to check with a local dealer if nobody has a better idea.
[Reply]  [No Email]
Jason S.
07-26-2012 06:35:23
174.252.156.215
 Re: Need help with MF65 steering shaft bearing in reply to will78, 07-25-2012 16:08:15
Have you ever tried going to federal moguls website and going
to their technical catalog? It has a place where you can put in
the id and od of a bearing you are looking for and it will list
several bearings that are either an exact match or a few
thousandths different in one of the dimensions. Massey lists a
bearing for my old DEO rake and it isn"t right. I used their site
and got one for it...the only difference was it was .020 thinner
which didn"t matter.
[Reply]  [No Email]
will78
07-26-2012 08:04:56
70.100.76.79
 Re: Need help with MF65 steering shaft bearing in reply to Jason S., 07-26-2012 06:35:23
Thanks Jason, I might try that. I just came from the local dealership and they supposedly ordered the correct one for me but its gonna cost $170.00!!! The part number they ordered is 1035054m91.
I tried googling this number and didnt get many results for it though. Really wish I could find it cheaper and even if its the right one.
This post was edited by will78 at 08:09:07 07/26/12.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
