| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Massey Ferguson 158F hydraulic filters
[Return to Forum]
| Author |
[Modern View]
| Chrisk
07-07-2012 14:52:21
188.28.130.119
I posted a message a while ago about my Massey Ferguson 158F and how the PTO and hydraulics didnt work. I have dropped the oil out of it and have cleaned the filter that was under the small plate at the back. Before puting new oil back in i put a mixture of oil and kerosene in it and drove it around a bit to wash the old oil around this was because the old oil had water in it. When i had this mixture in it the PTO and hydraulics worked but as soon as i put propper oil back in it the PTO would not work but when i tried the linkarms they would judder up about 300mm then drop back down then they would do the same process over and over agian. After leaving it a couple of days i ran the tractor again and when i tried the hydraulics nothing would work the link arms would not move at all. Does any one have any ideas what is wrong i have asked some people and some belive it is the hydraulic pump but others have said it isnt because it is showing the symptons the wrong way around eg: it works with a thin mixture and not a thick one rather than the other way around. Another idea a freind had was that there might be an internall filter inside the back end that is blocked up. Any help would be gratefull thanks. |
| samn40
07-08-2012 14:15:38
81.135.24.11
Re: Massey Ferguson 158F hydraulic filters in reply to Chrisk, 07-07-2012 14:52:21
| Is it the filter up inside the trans housing that you cleaned? or have you found another one? Your symptoms all point towards oil starvation or cavitation in the filter. I just wonder has someone fitted a non standard filter with too fine mesh? I have had problems with some tractors with the long filter (about 4-5 inches long) and converted these tractors to the short filter(about 3" long) and no more problems. The long filter seems to pick up every thing from the bottom first and very often when I took them out they looked perfectly clean,anyway I washed them in petrol and blew them out with the airline, 1 hour later ...the same problem, fitted a new filter...no better. So tried a short filter from an older tractor and 15 yrs later, except for routine servicing, never had to look at it. The short filter has to be held in place with a threaded rod screwed up through it into the pump, the long filter is spring loaded and is held up against the pump with the bottom plate. Hope that helps....Sam |
| Chrisk
07-09-2012 11:04:49
188.28.227.230
Re: Massey Ferguson 158F hydraulic filters in reply to samn40, 07-08-2012 14:15:38
| thanks that sounds interesting i will have a go at changing the filter for a shorter one and see what happens. |
| samn40
07-07-2012 17:21:24
81.135.24.11
| What oil are you using? It should be 15w/40 or super universal. Also you should have washed the filter again after flushing the tractor. Sam |
| Chrisk
07-08-2012 02:24:08
188.28.132.14
Re: Massey Ferguson 158F hydraulic filters in reply to samn40, 07-07-2012 17:21:24
| It has got super universal in it and sory i forgot to mention that i did clean the filter out after flushing it out thanks for the suggestion anyway. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
