Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Massey Ferguson 285 PTO Question
[Return to Forum]
Thomas MD
06-30-2012 13:02:42
75.192.140.159
I have recently acquired a Massey 285 and noticed that the PTO does not stop. I have tried the PTO lever in both positions and no change. I have not tried to hook up anything to the PTO yet, but i just wanted some opinions. Thanks in advance.
[Reply]   [No Email]
tg in VA
07-02-2012 15:08:00
75.210.92.140
 Re: Massey Ferguson 285 PTO Question in reply to Thomas MD, 06-30-2012 13:02:42
My MF 285 PTO shaft turns for a while after I start it but it usually quits on its own after a short while. If there is a piece of equipment atached, it doesn't start until I engage the PTO lever. I've had the tractor for 6 or 7 years and it's done it since day one.
[Reply]  [No Email]
lemmond1
06-30-2012 13:47:41
209.33.77.112
I have a MF 1085 which is similar to your tractor and It has the same problem--the pto turns all the time until I hook it up to a mower or some other piece of equipment then it quits. I hope this helps. Roy
[Reply]  [No Email]
samn40
06-30-2012 13:18:02
86.154.196.156
It could be that you need a PTO brake pad fitted to the IPTO hub inside the trans housing. But, it could be a weak pump or, worse case scenario, warped discs in the IPTO hub. To test the hub simply try to turn the the PTO shaft by hand with the engine stopped, if it turns with a bit of a drag it is OK but if it feels real tight and doesn't want to turn then the plates are probably toasted! To check the pump you will need a hydraulic pressure testing gauge. Someone over your side will be able to tell where the testing position is, usually it is beside the PTO selector lever but on some tractors it had a pipe from this position and a remote testing port. This test could also pinpoint a burst pipe or a valve sticking open thus releasing all the pressure to the brake pad.
Good luck and let us know your findings.....Sam
[Reply]  [No Email]
DavidP, South Wales
06-30-2012 14:02:32
2.101.102.191
 Re: Massey Ferguson 285 PTO Question in reply to samn40, 06-30-2012 13:18:02
To add to Samn40's comments;
With the engine at idle and the 'off' position selected on the control lever, try and prevent the pto shaft from turning using a piece of 3x2 wood or similar. If you are able to stop the rotation it would appear to be a brake pad problem.
DavidP, South Wales
[Reply]  [No Email]
Thomas MD
07-01-2012 10:20:01
75.243.149.118
 Re: Massey Ferguson 285 PTO Question in reply to DavidP, South Wales, 06-30-2012 14:02:32
I was able to stop the shaft with a block of wood and with the tractor running now it does not turn. So i would suspect the brake like you said thanks!!!
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
