I have Auxiliary Hydraulic Control Valve (Whole Goods 677219) installed on my 135.
The way it's currently set up, I use one of the levers to control the three point hitch and the other one if I use a cylinder.
When I put in the garden last week, I noticed milky fluid coming up from behind the plate that the levers bolt into. I've attached a parts diagram of the valve there is some kind of hollow check plug and o ring that goes behind that plate. Do I have to do a complete tear down of the valve?
(Unit as installed)
I've noticed most of the parts for this particular valve aren't coming up using jackssmallengines.com to check Epsilon.
My other question is, this valve isn't covered in the insert that covers the 100 series Auxiliary Hydraulics.
How can I use the quadrant controls with this system? I know I have to turn a knob, but which ones?
Thanks,
Christos
(Unit as installed)
Thanks,
Christos
