| Massey Harris & Massey Ferguson Tractors Discussion Forum |
Topic: Differential Leak
[Return to Forum]
| Author |
[Modern View]
| Steven, Avilla MO
05-29-2012 08:37:48
69.55.159.109
I have the same differential leak that is mentioned in a recent post. I believe the axle seal is leaking on the differential carrier plate. Oil then drips from the trumpet weep hole. I replaced the seal but there is a groove worn into the axle from the seal. I"m assuming I need to replace the axle. Does the planetary carrier need to be removed in order to replace the axle? I"m somewhat reluctant to disassemble the planataries because the MF manual makes it look complicated and technical. Also, it looks like there are 2 pinion axles and 3 pinion axles. Does anyone have any experience in this area? |
| Laneman
05-30-2012 03:02:33
199.115.190.204
Re: Differential Leak in reply to Steven, Avilla MO, 05-29-2012 08:37:48
| One more thing, make sure the axle is polished and smooth where the seal rides, any rust or pitting will also cause leaks. |
| Laneman
05-30-2012 02:57:01
199.115.190.204
| You may be still be ok with a groove in the axle, depends on how deep it is. A new seal will often work inside the grooved area as long as the seal can make good contact with the axle. You'll have to use your judgment for deciding how much of a groove is too deep. |
| Masseynut(Australia)
05-29-2012 13:26:09
60.231.86.10
| Hi Steven, You don't need to replace the axle, a "speedi-sleeve" will solve the problem. You can remove the axle from the epicyclic end quite easily, but you will need to replace the "cork" gaskets if either or both are disturbed. No re-setting of the bearing pre-load should be necessary if it is already with-in specs. Just remember to drain both the transmission and the final drives first. When attempting to remove the epicyclic hub, lock the brake on that side first. This ensures that the brake discs are locked in a position, whereby the axle can be returned to the housing with minimum fuss and effort. Evan. |
| Steven, Avilla MO
05-30-2012 06:08:49
69.55.159.109
Re: Differential Leak in reply to Masseynut(Australia), 05-29-2012 13:26:09
| Thanks for the responses. Evan, how is the stub wheel axle held in place? Does that require disassembly of the planatery? I think the outside wheel axle seal is leaking a tad. I thought about fixing that as well. What would you charge to replace all seals in the trumpet/planataries if I removed and shipped over to you? Every once in a great while we ship some pallets your way. |
05-30-2012 13:15:05
60.231.86.10
Re: Differential Leak in reply to Steven, Avilla MO, 05-30-2012 06:08:49
| Depending if your machine is pre or post 100 series, the axle retaining idea varies a little. Mf 65's and early industrial 40's used a two piece retaining spacer, where as the later Masseys used a snap-ring and relied on the axle being an "interference" type fit in the hub. Meaning that once the snap ring was removed, the axle was then pressed out of the hub at around 30 tons. Once removed, replacing both the seal in the differential carrier plate, the inner and outer final drive hubs, and wash-up, should take around 2 hours tops, provided everything else is in good order. Evan. |
| Steven, Avilla MO
05-31-2012 07:39:51
69.55.159.109
Re: Differential Leak in reply to Masseynut(Australia), 05-30-2012 13:15:05
| Thanks Evan. I have a 1965 165. So I guess that means I need a 30 ton press? Are you anywhere near Hallam VIC 3803? Two hours works means about $150 dollars right? |
05-31-2012 13:14:54
60.231.86.10
Re: Differential Leak in reply to Steven, Avilla MO, 05-31-2012 07:39:51
| Yes, Steve, the 165 model will need pressing. I am two states and 1000 miles north of Hallam, up the sunny state of Queensland. Road freight would be expensive, as the price of diesel here at the moment is over $1.50 a litre! That equates to roughly $6.75 a gallon in your speak. You can do the sums to get it here, and I'd be more than happy to do it for you. $150.00 is spot on. regards, Evan. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
