Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: massey ferguson 50
[Return to Forum]
grtrnd1
05-28-2012 11:49:44
205.188.117.17
I have a Massey Ferguson 50 with a Z134. I rebuilt the motor a couple years ago and replaced everything new except for the ball and cage type governor. The only reason i didn"t replace it is because it worked like a new one before the motor was rebuilt. The motor works great, starts quick, idles perfect but the governor does not work. Is there any way to check it without tearing the whole front of the tractor off again. Thanks.
[Reply]   [No Email]
2tractors
05-28-2012 16:45:05
207.144.5.133
 Re: massey ferguson 50 in reply to grtrnd1, 05-28-2012 11:49:44
My 50 does the same.I thought i had found the problem while working on the 35 and noticed the spring that hooks on the water pump was missing on the 50, replaced it and reset tension and friction washer. Mine is still "creeping". Let me know what you find.
[Reply]  [No Email]
Tony in Mass.
05-28-2012 14:40:42
76.118.216.103
Taking a shot in the dark here - with no pictures... does it have no springs? Or the springs just unhooked and hanging there? but not having tension to return the rod?
[Reply]  [No Email]
Dieseltech
05-28-2012 12:02:03
199.16.223.2
Make sure carb to gov rod is not binding, and length is not set too short as gov action will be sluggish, if set too long will cause a surge problem if weight unit is working correctly. Have also seen tractors that need gov shaft needle bearings and shaft replaced in timing cover too. All parts must work freely and pin holes not be extremely loose from wear for good gov action.
[Reply]  [No Email]
grtrnd1
05-28-2012 12:11:44
205.188.117.17
 Re: massey ferguson 50 in reply to Dieseltech, 05-28-2012 12:02:03
I have a service manual for this tractor and have adjusted everything exactly as the book states. Still can't get it to do anything. Another thing that I forgot to mention and I apologize is, when the tractor is at an idle, the idle will creep up on it. I have replaced the friction washer with a new one and still does it. If you are going down hill and throttle down to an idle, the tractor will still gain RPM's, you have to hold the throttle lever foward in the idle position for it to stay at an idle. Is there anyway to tell by grabbing the governor rod where it goes through the cover to tell if the lip on the cage is in the wrong place. I remember reading when putting it back together that the lip on the cage had to be in the 8 oclock position.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
