r david smith
New User
I am inquiring for an elderly gentleman who has a MF 165 gas. He wants to adjust the internal hydraulic linkage setting. The manual calls for a "gauge", part #mfn 970, that is required to make this adjustment. This tool apparently is no longer in production. There are 2 cover thicknesses this tool will work for(according to the manual). The cover thickness on this model is 1 1/8". A 3/8/" steel plate or bolt is not the correct thickness.
I have seen the photo of this tool. Seems rather easy to fabricate if you have the dimension specs which we do not have.
Would appreciate any help locating a tool or specs.
