Anonymous-0
you seemed to be interested in the sawmill, I took some pics of the sawdust chain I rigged up. I used chain and sprockets from an old JD combine. The chain is run with a hyd motor and supplied by the hyd off the 1105. This is the prototype, I will improve everything when the weather turns warm. :D
Ya know, if you had a hedgehog, with scuba diving flippers, you wouldn't need this big contraption....
You'd have more hydraulic pressure if you raised the tractor a foot too.
You might want to ask this gang what the story of the 1000rpm shaft is. Cleaver fellers this Massey crew....
