Massey Harris Pony Timing
Larry999
I bought a Massey Harris Pony that was not running. The guy I had bought it from had tried to get it running. I found he had the spark plug wires crossed and the gas line was stopped up. I did get it running, but it is not right. It does not have enough power to pull itself. I think the timing may be off. I looked for the timing mark on the fly wheel but could not find it. Is the mark deep and easy to find or is it a shallow line that can be hard to see? Is it located close to pressure plate bolt hole or some other reference mark?
Or the carb needs cleaning/adjusting/repair. They are very fussy about slack around the throttle shaft. And be sure there is a good seal between the two halves of the carb.
