When I got my MF35, the fuel gauge was disconnected (AND very old). It was marked as a 30-240 ohm gauge. I couldn't get it to work, so I ordered an original MF replacement sending unit (after-market, but touted as being identical in all respects) and a new 30-240 ohm fuel gauge... Every thing worked perfectly for about 2 hours, then the fuel gauge pegged at full and won't move until I turn it off (when off, it returns to EMPTY, so the gauge is not STUCK)...
I tried to test the sending unit, but with my itty-bitty, rinky-dink tester I couldn't figure out if it was sending 30-240 ohms (but the tester's needle did move back and forth when I moved the float up and down)...
So, does anybody know if the 30-240 gauge is compatible with the MF sending unit? (The tractor place where I bought it said, "Yes, it is.")...
Does anybody know how to fix this particular issue? Do I need to put a resister in the wire or something?
Thanks.
8)
Thanks.
8)
