You all knew there was going to be a daft question on the way...
We took the fuel lift pump off the MF40 to clean up the pump and area - it's caked in many years' build up of grot. Pump came off nicely. However, putting it back isn't quite so easy. Well it's easy to put it back with the curved lever part of the pump locating above the camshaft (I presume it's the camshaft?) but it won't go in with the lever below the camshaft (the studs for fixing the pump aren't coming out any time soon).
Is the pump meant to be actuated by the camshaft? I'm presuming it should be. Should the curved lever be under the camshaft? If so, how do I get it installed correctly?
Yes, a service manual is very high on my priority list but locating one is not being easy!
Your help greatly appreciated.
Cheers
Cheers
