Vineyard_65
I have to change the Wheel spacing on my 1964 Std,MF-65 from 72" to 64" so that it will fit between the vines.
The 4 sided, bolts on the Rim Locks & stops aren't wanting to budge. I've sprayed them every day for week with WD-40 hoping that they will break free. For tools, so far, I've tried:
- 1/2" female pipe plug/square socket (too small)
- several sizes of 6 & 12pt sockets (rounds edge off the bolt)
- 13mm open end wrench (fits well but can't get enough leverage to break these free. makes a nice impression on my hands, though?
- 1/2" open end (too small)
- 9/16" open end (too loose)
Talked to the local tool truck, and they don't sell a 13mm female pipe plug socket. Looked online for bit but didn't see anything.
Massey operators manual show a too kit which came with the tractors, but mine had none. Dealer looked at me like I was nuts when I asked if he could order one....
What have you folks used which worked to loosen/tighten the Rim stop bolt and rim connector bolts which are 4 sided? I'm pretty sure I'm not the 1st guy to try change wheel spacing w/o the MF factory tool.
Many Thanks!
-sb
Many Thanks!
-sb
